LT1/LT4 Tech 1993-1997
Trans cooler effect on engine temp
Old Apr 17, 2011 | 12:12 PM
Mr_Exacto's Avatar
Default Trans cooler effect on engine temp
I have a '94 Camaro Z28 with a 4L60E trans. My transmission overheated and needs to be replaced. I am going to take this opportunity to get a converter with a higher stall too. That said, I want to get a trans oil cooler installed to keep the trans from overheating again. Does mounting a trans oil cooler on the radiator cause the engine to run hotter? Second, would the Compressor Works (part 911514) trans cooler at Autozone be a good option?
Link to Compressor Works trans oil cooler:
Compressor Works/Transmission Oil Cooler (911514) | AutoZone.com
In this link, a guy mounted a Hayden trans cooler to his radiator and did not see an increase in engine temperature. I wonder if this is the case for everyone.
4L60E Transmission Oil Cooler Install
Old Apr 17, 2011 | 12:47 PM
that cooler looks to be for a v6 setup. check here. the design is better, cools more like a radiator. maybe autozone can order them. its #9der about 2/3 way down the page. cooler should not have an effect on the motors temp. if anything it may drop it a bit because the trans fluid coming it is a bit cooler.
Derale Cooling Products
Old Apr 18, 2011 | 12:15 AM
Mr_Exacto's Avatar
Craby, thanks for the feedback. Just curious - how did you know that the trans cooler from Compressor Works was for a V6? According to the AutoZone website, it fits a '94 Camaro Z28.
Old Apr 18, 2011 | 08:52 AM
my bad, your correct it will fit a 5.7 as well. lol,,, dont know what i was thinking.
libertyforall1776
Feb 17, 2015 09:16 AM
greenmachine96
10
Feb 20, 2014 09:06 PM
Crunchy
Feb 5, 2009 04:38 PM
dustinb
Oct 1, 2007 09:39 PM
