LT1/LT4 Tech 1993-1997
Tranny problems!!
Old Apr 6, 2010 | 09:54 PM
Jmoss13's Avatar
Default Tranny problems!!
I have an automatic in my 95Z. Recently I rebuilt the transmission and for about a day after it worked like a charm. Then the transmission stopped shifting automatically into all gears. All of the gears still work fine but you have to let off the gas a higher RPMs to allow it to fall into gear. Solenoids, wiring harness, what??
any help would be great.
PS it has proper fluid level.
Old Apr 7, 2010 | 08:39 AM
peej07's Avatar
I have a similar problem too, at wot it wont shift until you let off.
Old Apr 7, 2010 | 12:34 PM
frankzlt1's Avatar
try disconnecting your negative battery cable for about 5 min this should reset the pcm. try that to see if it works also you should try to scan the car for any codes
Old Apr 7, 2010 | 01:04 PM
yes unhooking the battery clears the codes too. have it scanned before unhooking the battery.
Jakobzara
May 9, 2008 12:29 AM
6v49der
Feb 21, 2008 01:20 AM
hurley870
Jan 28, 2007 11:55 AM
scottish_camaro
Nov 19, 2006 03:29 PM
Bubonic
Sep 1, 2006 10:10 PM
