LT1/LT4 Tech 1993-1997
Threw a code..MAF?
Old Sep 9, 2009 | 09:08 PM
BlueDevil Z's Avatar
Default Threw a code..MAF?
So my service engine light came on in my 97 Z28 while driving down the road. Stopped at an orielly's and had it checked. It was reading the code for the Mass Air Flow Sensor. The thing is it was running normally and i didnt notice anything wrong...missing or rough running or anything like that. Guy at Orielly's said it could simply be a fluke? He went ahead and shut off the engine light. So, what would make it read that code? what usually happens when you have trouble with an MAF or have one go out? What should i be looking for to really be sure theres something wrong with it? Thanks.
Old Sep 10, 2009 | 01:39 AM
95slvrZ28's Avatar
If the MAF is actually giving bad data to the PCM the car will go into open loop mode where it meters air off of the MAP sensor to determine the mixture and ignores the MAF and O2 sensors. This will result in a rich condition 99% of the time since the MAP fuel tables are programmed to be rich. You probably won't notice much of a decrease in actual driveability. Sometimes there can be weird issues with the connector and the PCM will throw an SES light. Disconnect and reconnect the MAF, see if the SES light comes back. If it does, it could be time to purchase a new one.
Old Sep 10, 2009 | 01:42 PM
gmkartech's Avatar
Was it a po101, if so that is a performance code, usually do to air filter being dirty or a k&n
Cam02ss
General Racing/Tech
12
Aug 2, 2011 08:38 PM
imcdowel
Mar 16, 2011 07:46 PM
Kendagenius
Dec 16, 2010 04:53 PM
maybe next time
82-92 V8 Tech
Jul 29, 2010 07:56 PM
joeyninetoes
Sep 10, 2008 12:03 AM
