engine threw a code p1404
Old Sep 9, 2008 | 07:21 PM
joeyninetoes's Avatar
Default engine threw a code p1404
definition
EGR valve stuck open
explanation
while monitoring the EGR valve pintle positionthe ECM detected
the closed position sensor voltage higher than the learned closed position
voltage
Probable Causes
1Failed EGR Valve
2Carbon blockage of the pintle.
can anyone explain this, maybe tell me where it is, what is the pintle?
also, a day after i got the code, i had it checked, than the next time i turned on
my car the SES light was off.
the above explanation was from autozone
thanks
Old Sep 9, 2008 | 07:47 PM
Default RE: engine threw a code p1404
Try removing the EGR and clean it out including the gas passages. The pintle is the part that moves (something like a stopper) and opens and closes the passage between the exhaust and intake.
Old Sep 10, 2008 | 12:03 AM
sallo's Avatar
yeah to start just remove the egr and clean it out good like pete said but if that doesnt work its probably the actuator part of the pintle and youll have to replace the egr valve.
'Maro!
Mar 16, 2014 03:11 PM
pajen
Jul 31, 2012 07:12 PM
BlueDevil Z
Sep 10, 2009 01:42 PM
bluovlh8er
Jan 13, 2008 02:34 PM
rayden7157
Jun 5, 2007 05:07 PM
