LT1/LT4 Tech 1993-1997
thermostat question
Old Jan 28, 2010 | 05:47 AM
CNCman's Avatar
Default thermostat question
Does anyone know a good and reliable 160 deg thermostat I can order online ? 94Z28 Lt1
Old Jan 28, 2010 | 07:54 AM
whammer3024's Avatar
ROTM Winner
hypertech sells a solid one
Old Jan 28, 2010 | 11:00 AM
Don't waste your time or money. For some reason, some car guys seem to think that 190-200 degrees is a bad temperature? A lower stat doesn't help the cooling system if the radiator fans don't come on any sooner, and it could actually make it so the radiator never gets a chance to chill the coolant like it's designed to. Even if the fans did come on sooner, 160 is way too cold for the engine to run efficiently and properly. Keep the stock stat in place and make it so the fans switch on sooner if your car seems to be reaching meltdown temps. There's absolutely nothing wrong with an operating temp in the 190 degree range if you can make it hang there with the fans.
Old Jan 28, 2010 | 11:18 AM
Mr_Exacto's Avatar
I have a Hypertech 160 thermostat that I no longer use and I agree with Camaro 69 on this. In addition, the 160 deg thermostat did not make my car run cooler. It just made the engine take a little linger to get to operating temperature, especially in cold weather. When I had an overheating problem, all it did was take a little longer to overheat. This probably won't help my cause for trying to sell it in the near future.
Old Feb 1, 2010 | 05:57 PM
ESPxCONxXx's Avatar
slp sells one fo rlike 40 or 50 bucks.
Old Feb 1, 2010 | 07:30 PM
$40 to $50 for a stat? It better be gold plated. I guess there is always a sucker. lol
A cold engine does not make more power, what makes a difference is cold air going into the engine. The hotter an engine can safely run, the more efficient it becomes, because less energy (heat) gets wasted. If it were so easy to make more power, factories would be using cold thermostats instead of expensive intercoolers when using forced induction. The last time factories used 160 degree stats was way back when antifreeze was still made with alcohol, and would boil off at higher temps.
Old Feb 2, 2010 | 06:26 AM
sm515's Avatar
i think he meant the switch to turn on the fans whenever ya want was 50$ by slp........well worth it....sittin in a drive thru getin close to redline, hit the switch and u can see the needle drop....keep the old thermo...done deal.
Old Feb 2, 2010 | 02:07 PM
ESPxCONxXx's Avatar
nahh, im tlakin about the stat. i have the stock thero in, and when my **** gets hot, i just flip the switch to high or low setting, and it goes down very quick..but like everybody else is saying keep the stock one in
Old Feb 3, 2010 | 09:52 AM
murderd96z28's Avatar
Get the slp fan switch! Keep the thermostat and just get the switch it is the best thing you can get for the car. When it gets hot just hit the switch. It's the next best thing from sliced bread
Old Feb 3, 2010 | 03:02 PM
black95z28's Avatar
if i got that switch, i would forget to ever turn the thing on. my car came with the 160 degree stat and it does take forever for it to run good and get the heat going in the winter time.
Dana
Aug 30, 2012 11:38 AM
70_Camaro
Mar 7, 2012 12:42 AM
TheGrimReaper73
Dec 12, 2008 07:58 AM
Captain205
82-92 V8 Tech
Jul 31, 2008 02:43 PM
camaro girl
Mar 18, 2007 11:32 PM
