LT1/LT4 Tech 1993-1997
Sluggish acceleration, hard start LT1
Old Jun 27, 2010 | 05:37 PM
chris76's Avatar
Default Sluggish acceleration, hard start LT1
95 Z28 LT1
88tkm - 55k mls
weekend and sunshine vehicle
Hi, i've got a problem with my camaro,
since last weekend it cranks a while before it starts, but then when it runs in idle everything seems to be ok. nothing sounds bad.
then when i try to accelerate, it does take gas but not as good as it did before last weekend and the pedal seems to be very soft as i had more resistance from the pedal before. the engine doesn't seem to misfire or splutter.
also when accelerating via cruise control it doesn't give me the power it did before.
i put on freescan and scanned for trouble codes but didn't find some, it says that the throttle position is up to 100% when i go on the pedal, so i dont get what it could be.
the car has no oil in the water or something like that, everything seems to me quite normal, and isn't leaking oil or water.
I found a thread about an 3.4 engine with likely similar problems, but the thread was older and i don't know if a v6 problem can be transferred that easy to a v8 problem.
does anyone have an idea what to test for or to replace?
Sorry for the bad english.
Old Jun 27, 2010 | 07:46 PM
FSTKMARO's Avatar
did you do a visual around the throttle body area? Any loose vacuum lines?
Old Jun 27, 2010 | 08:28 PM
i would look at fuel pressure first. also how long from its last spark plugs and how old is the opti? changing the fuel filter would be in order as well if its not been changed it a long time.
Old Jun 28, 2010 | 03:32 AM
chris76's Avatar
i had the fuel pump replaced last year and fuel filter also. about the spark plugs i have to ask my buddy who did the stuff for me last year. the optispark is afaik the first one since the car didn't take 60k mls line yet.
will check for the vacuum lines and about the sparks today.
Old Jun 28, 2010 | 08:37 AM
if a cheap fuel pump was used,,, well either way check fuel pressure, test your evap sytem and fuel pressure regulator as well.
sounds like it may be a good time to change the opti, plugs and plug wires. i would recomend the gm performance opti and second choise would be msd.
Old Jun 28, 2010 | 11:36 AM
chris76's Avatar
yeah i heard of that cheap ones.
i've bought mine (ACD 43-914 ) from rmsautoparts, so i think that would be ok.
i will check with my f-body specialised mechanic, for checking the plugs and wiring, etc. since the problem occured first when a heavy rain cloud surprised me.
edit: is there any way to see other peoples car pictures if i'm below 10 posts?
Old Jun 28, 2010 | 08:49 PM
your half way there. i dont see why you couldnt go to albums but that may be the way it is. is that what your talking about?
Old Jun 29, 2010 | 04:15 PM
chris76's Avatar
i had a look at the lines around the engine and stumbled over something which I think could be the problem
i've put marks in a picture of another lt1 where one of the lines in my car looks very porously.
maybe i'll try it with taping that one and see if the problem still exists.
Update:
after taping that one the car starts as it should and it accelerates about 50% of time how it should, but the pedal is not giving drag (and feels then softish) all the time and then acceleration is quite low compared to what the car is capable.
anyone with an idea?
will bring the car to my mechanic on thursday for having the sparks replaced and fuelpressure checked. i don't want to buy a new opti....
JWT
82-92 V6 Tech
Jan 30, 2011 08:13 PM
propaganda
Nov 27, 2009 03:32 AM
vtwin87
Oct 8, 2009 12:09 AM
Charley28
Sep 5, 2009 12:05 PM
scrymsmary
Apr 28, 2009 02:43 PM
