Intermittent Hard Start. No Acceleration when pressing gas pedal
Old Jan 30, 2011 | 06:10 PM
JWT's Avatar
JWT
Unhappy Intermittent Hard Start. No Acceleration when pressing gas pedal
I have a 1992 Camaro 3.1
I have a problem what sometimes the car just will not start. It will crank and crank until you can actually smell gas and then finally it will start up and run fine.
Other times while driving, if you press the gas pedal, there is virtually no acceleration.
Where should I start? Fuel pressure? Fuel pump?
Old Jan 30, 2011 | 08:13 PM
Check fuel pressure and pressure regulator first, this will tell you if the pump is good or not, and if there are injectors leaking. Also check for restriction in exhaust system.
Tommyboyink
Oct 20, 2011 12:11 PM
Tater
Jul 23, 2010 08:16 PM
chris76
Jun 29, 2010 04:15 PM
propaganda
Nov 27, 2009 03:32 AM
dhighway
Feb 23, 2008 11:43 PM
