LT1/LT4 Tech 1993-1997
Replacing optispark
Old Oct 13, 2009 | 05:30 PM
change the plugs first. i know its a pain but 9 yr old plugs cant be to good. just the improvments they have make from then on plugs will make it worth it. if u do the opti do the water pump. if not u may have the pump go in a couple months and kill your new opti. check the plug wire before so if they are lookin sad change them while the water pump and stuff is outa the way. do like 69 said and have it scanned and see what comes up. might save a few hundred.
Old Oct 13, 2009 | 05:33 PM
jamesfs912's Avatar
Well om I will do that. Thanks just saved me $150. Probably will get on that next week
Old Oct 13, 2009 | 07:37 PM
383Stro's Avatar
everyone is always replacing the water pumps on our cars prematurely i think. It mechnically driven (has no choice but to spin) and has a steel impeller that spins on bearings. There is a rubber o ring that is thin but wide that is on the front cap when you take off the 6 or so screws in the front that leaks and needs replacing sometimes, but i just dont see where the things fail that often I have only seen one bad waterpump and it leaked around the bearing seals on a car with well over 200,000 miles. Have you guys taken one of those things apart and looked at them? They are so basic. I dont even think they have a weephole and with good reason with the opti underneath.
Old Oct 13, 2009 | 09:19 PM
I just recently replaced my opti, and the water pump while I was at it. With 98k miles, I looked at it as cheap insurance, especially since the damn thing was already in my hand. I wasn't trying to pinch pennies, plus it'll never be any easier of a job than when it's already off. And I now have an emergency spare one too.
Old Oct 13, 2009 | 11:13 PM
Originally Posted by jamesfs912
Is that temp abnormal? I have only owned it for about a month and a half so its normal to me lol. Well I checked the coolant and its rusty. FML lol. Probably why it is running hot. I'm thinking there is water in there(coolant can't get rusty can it?)Could this cause my idle issue. BTW i'm just going to replace the damn optispark anyway and the water pump for fun.
its on the upper range of were it should be. mine hangs at 180 but i have it tuned that way. if u have all water it will boil over ealier than if half and half and yes anifreeze inhibits rust. i dont think its the issue with the idle. i would look to the plugs first on that. check fuel pressure and have her scanned or do yourself. when i brought my current car home the first time it wouldnt run the morning after i got it home. changed the plugs and bingo. ran great.
sbono
May 22, 2009 02:48 PM
tx26firebird
Jan 5, 2008 11:25 AM
luvmysccamaro
Dec 26, 2007 04:04 PM
KoRN_Munky
Dec 24, 2006 04:35 AM
