Replacing Optispark
Old May 22, 2009 | 02:21 PM
sbono's Avatar
Default Replacing Optispark
I'm replacing the opti with a new one from summit. My question is do I have to line up the rotor in the same location as the old one I took off to keep the timing corrcet or do I simply put it on? The reason I ask is that it seems like a sealed unit and I don't want to break the seal if I don't have too. Thanks
Old May 22, 2009 | 02:28 PM
yes u should take the cap off. there are gears missing in the drive splines so it will only go in right one way. if u force it on the wrong position u can ruin it. sumitt dist. are rebuilt but i guess u got it already and i dont think u can send it back. rebuilt opti's arent the most dependable. theres a rubber o ring between the cap and dist. dont lose it, and seal the cap with some high temp gold or blue rtv to help it seal better when u put it back together.
Old May 22, 2009 | 02:48 PM
sbono's Avatar
Thanks Craby, I actually bought a GMPP from summit just because of what I have read about summit remans.
jamesfs912
Oct 13, 2009 11:13 PM
tx26firebird
Jan 5, 2008 11:25 AM
luvmysccamaro
Dec 26, 2007 04:04 PM
KoRN_Munky
Dec 24, 2006 04:35 AM
