LT1/LT4 Tech 1993-1997
Replacing the Clutch
Old Jun 30, 2009 | 12:51 PM
97SuperSport's Avatar
Exclamation Replacing the Clutch
Within the next week or two I will undergo the task of replacing my clutch. I have replaced many clutches before, so the I have the experience to do so. I was just curious as to if there was anything I needed to know before hand. Any tips in making it go easier, anything in the way, etc. I have searched the forums and couldnt find a thing. Any help would be much appreciated. Thank you
Old Jul 1, 2009 | 12:08 PM
95slvrZ28's Avatar
The hardest part is probably going to be disengaging the clutch fork so you can separate the transmission from the motor in order to get in there and replace things. If you've done clutches before, have fun!
Old Jul 3, 2009 | 04:13 PM
97SScamaro's Avatar
My father and I replaced our clutch over the winter and do to the fact that they cram everything into the F-bodys there is little room to work. You absolutley need a transmission jack or its close to impossible(we did it without one....its a nightmare). there is so little room to work with under the car that everything needs to line up perfectly in order for the trans to go back on smoothly. Needless to say my dad threatened giving up and selling the car as is hah so i wish you luck.
djsquare1
Sep 12, 2012 11:42 AM
xXChipXx
Jul 27, 2010 06:08 PM
Skippysnax
May 17, 2008 08:28 PM
hurley870
Sep 26, 2007 10:23 PM
