LT1/LT4 Tech 1993-1997
remvoing exhaust manifold
Old Mar 8, 2012 | 12:25 PM
borjawil's Avatar
Default remvoing exhaust manifold
Ok so replacing the head gaskets and have gotten over to the passenger side manifold. Cant get to the last 2 bolts closest to the firewall. Not a whole lot of room in there. Any ideas, tips, tricks to getting these out?
Old Mar 8, 2012 | 01:02 PM
Failed Devices's Avatar
Have you tried getting the bolts from under the car as well? When I did headers on my ls1 i bought a ratchet with a pivoting head which helped a lot
Old Mar 8, 2012 | 01:18 PM
DrQuincy's Avatar
Or maybe a ratcheting wrench?
Old Mar 8, 2012 | 02:40 PM
borjawil's Avatar
i removed the bolts that connect the Y pipe. Not room to get up there from underneath. Once I removed the valve cover I had enough room. I do have a pivot joint for my ratchet its saved me numerous times. Got the manifold off and the ps pump unbolts but cant get the bottom hose off of it. guess ill try some pb blaster and/or a torch..
meteoralp45
Aug 4, 2008 04:56 PM
The Banks
Mar 8, 2008 12:26 PM
cheever1804
Dec 30, 2007 10:42 PM
jimidude87
Apr 7, 2007 03:18 AM
Z28man
Sep 8, 2006 12:48 PM
