LT1/LT4 Tech 1993-1997
magna flow exhaust
Old Mar 5, 2012 | 10:11 PM
Robert Macpherson's Avatar
Default magna flow exhaust
i have a 1993 camaro with a 1997 350 with a new cam that gives it a 4inch stroke which makes it a 1997 383 engine. i am looking at getting magna flow exhaust for this car only muffler and tip and i want a deep but loud sound. i am completely clueless when it comes to exaust. will someone give me some information on how to pick which mufflers and tips would produce the sound i am looking for and which muffler and tips would simply be the best for this car?
Old Mar 6, 2012 | 02:53 AM
Catmaigne's Avatar
If the engine is really a 383 then the cylinders should be overbored to 4.030" and the stroke should be increased to 3.75" by using a stroker crankshaft. A camshaft will only change the timing and lift of your valves, not displacement.
The Magnaflow is a good system for DD and sleeper cars because it's fairly quiet under 2000RPM and has minimal interior drone. If you're just looking for a deeper and louder sound it would be best to go with a Hooker or Flowmaster catback system for the least amount of cash. The Magnaflow might be a bit too mild for what you want.
Old Mar 6, 2012 | 10:40 AM
torque_is_good's Avatar
a camshaft doesn't increase stroke.
The magnaflow is a fine system and it's stainless. be sure to check streetside auto for pricing as they tend to be the most competitive
Old Mar 6, 2012 | 11:17 PM
numskull223's Avatar
I have to agree with everyone about a 4in stroke 383. should be a 3.75 stroke crank.
But as far as magna flow muffler, I run that on my 383 z28. Here are a couple of sound clips
Thes clips are before I fixed my rattling exhaust pipe, if you listen hard on the first video you can hear it. I made a aluminum spacer to pull it off the suport under the car now.
Idle clip & Rev - YouTube
1995 Cammed 383 Z28 - YouTube
Old Mar 7, 2012 | 08:29 AM
depends on how much money you have to spend. if you have funds i recomend stainless. borla makes an adjustable cat back so you could adjust to your likes. on the high end for cost corsa makes a great cat back that is one of the best as far as low rpm noise reduction and high rpm air flow with very nice sound and minimal drone.
Old Mar 7, 2012 | 09:10 PM
your car sounds awesome numskull!!! i want mine to sound just like it!
and i have considered borla but it runs about $900 for what i want and my budget is more towards $400ish so magna flow is a good option for me and i have heard alot of good stuff about magna flow. so if i am correct the fouteen inch muffler would be alot louder then the 18 or 24 inch mufflers?
Old Mar 7, 2012 | 11:16 PM
Thanks....as far as the muffler I believe you are correct....Craby would know for sure, He is the go to man!!
Old Mar 8, 2012 | 09:29 PM
thanks!! you guys are a great help!!
iLL95
Oct 2, 2011 01:10 AM
purpl96
Aug 17, 2007 06:17 PM
bFc89
Jul 2, 2007 08:49 PM
SScamaro22
Apr 17, 2007 09:37 PM
akohnz
May 26, 2006 01:13 AM
