rear end leaking need gear info
RE: rear end leaking need gear info
ORIGINAL: camarorz28
Anyone know how much a shop would charge to change the seal? i really dont want to try it myself i dont want to screw up.
ORIGINAL: blackz87
Just replace the pinion oil seal and you will stop the leak a cheap fix for your problem. Poor excuse to make a gear change in my opinion.
i called a local shop, and they told me that most likely the bearings to the pionion would be bad, could i possibly be changing new bearings too? also i call another local shop and they want 399 labor plus parts, there is a salvage yard that sells a differential for 400 dollars should it be worth fix the one on the car
ok, but wat if the bearings are loosing need to get lubricant and they dont seem to have any, i haven't put any oil to the differential which is kinda stupid but i will be putting some in there this weekend, cuz i dont want any internal damage such of gears and stuff, i'll just keep shoping around to see what kinda deal i get
get a shop to do it. i had a friend to replace mines for me. within that hour my gears locked up. i watch him put gear oil in the car. take it to the shop they know what type of gear oil and seal to put on.
is there a spec. for the torque? on the Nut so i can be tight with some sort of tool? i'm at a school shop and they have alot of special tools all i need its to know what is the name and if there is such tool? also is there a tool that can record what the acctual torque is on the Nut already
