LT1/LT4 Tech 1993-1997
rear end leaking need gear info
Old Sep 7, 2007 | 07:27 AM
blackz87's Avatar
Default RE: rear end leaking need gear info
ORIGINAL: camarorz28
ORIGINAL: blackz87
Just replace the pinion oil seal and you will stop the leak a cheap fix for your problem. Poor excuse to make a gear change in my opinion.
Anyone know how much a shop would charge to change the seal? i really dont want to try it myself i dont want to screw up.
About $100.00 more or less.
Old Sep 10, 2007 | 09:21 PM
camarorz28's Avatar
i called a local shop, and they told me that most likely the bearings to the pionion would be bad, could i possibly be changing new bearings too? also i call another local shop and they want 399 labor plus parts, there is a salvage yard that sells a differential for 400 dollars should it be worth fix the one on the car
Old Sep 11, 2007 | 06:37 AM
blackz87's Avatar
I think you are getting a line of BS. Pinion oil seal failure is a coomon occurance on 3rd gen cars and bearing failure would be very, very rare. Avoid these rip off shops with there no see estimates.
Old Sep 11, 2007 | 05:16 PM
camarorz28's Avatar
ok, but wat if the bearings are loosing need to get lubricant and they dont seem to have any, i haven't put any oil to the differential which is kinda stupid but i will be putting some in there this weekend, cuz i dont want any internal damage such of gears and stuff, i'll just keep shoping around to see what kinda deal i get
Old Sep 11, 2007 | 07:04 PM
blackz87's Avatar
You are not lossing that much fluid from that rear though the pinion brg seal.
Old Sep 14, 2007 | 04:46 PM
sl1foru's Avatar
get a shop to do it. i had a friend to replace mines for me. within that hour my gears locked up. i watch him put gear oil in the car. take it to the shop they know what type of gear oil and seal to put on.
Old Sep 15, 2007 | 05:02 PM
camarorz28's Avatar
is there a spec. for the torque? on the Nut so i can be tight with some sort of tool? i'm at a school shop and they have alot of special tools all i need its to know what is the name and if there is such tool? also is there a tool that can record what the acctual torque is on the Nut already
Sicilian
Aug 1, 2013 11:42 PM
exador
Jan 29, 2013 12:38 PM
larco
Jun 16, 2012 10:11 PM
bbjk08
Oct 13, 2011 09:06 PM
marrow
May 3, 2005 11:22 PM
