1993 V6 3.4L Timing Gear Info
Old Jun 16, 2012 | 02:10 PM
larco's Avatar
Default 1993 V6 3.4L Timing Gear Info
On a 3.4L timing chain when it is on top dead center for #1 cylinder should the timing dots be at ( camshaft at 6 o'clock and crankshaft at 12 o'clock or should they be camshaft at 12 o'clock and crankshaft at 12 o'clock?
Old Jun 16, 2012 | 10:11 PM
suposed to line up the marks on the crank and cam sprockets with the cast timing marks on the block and/or the timing marks on the timing chain damper, cam at 6 crank at 12.
95ConvertibleRo
May 18, 2020 09:56 PM
larco
Aug 3, 2012 09:49 PM
Emgarbs
Oct 7, 2010 04:52 PM
travis t
Jun 5, 2008 04:42 PM
2lucke4u
Apr 23, 2007 02:07 PM
