LT1/LT4 Tech 1993-1997
question about gears
Old Jun 6, 2007 | 01:08 PM
1bad96Z28's Avatar
Default question about gears
Hydra-matic 4L60E Automatic 4-speed with Overdrive
1st: 3.06
2nd:1.63
3rd:1.00
4th:0.70
Reverse:2.29
Maximum Upshift MPH
1-2nd: 48mph 2-3rd:93mph 3-4th:150mph= 2.73 Axle
1-2nd: 36mph 2-3rd:73mph 3-4th:126mph= 3.23 Axle (performance axle)
does this mean that if im shifting from 1st to 2nd at 48 that i have 2.73 gears? all my stickers are gone as well as the spec plate on the bold on the axle
Old Jun 6, 2007 | 01:09 PM
1bad96Z28's Avatar
Default RE: question about gears
but someone on here told me that i have a 700r4 transmission cuz i cant shift down in to 1st gear. its an auto. sure you know that already but anywho.
Old Jun 7, 2007 | 02:08 PM
95slvrZ28's Avatar
Unless the transmission has been swapped out, you have the 4L60E. If it has been swapped, then you need to find out what gear ratios you have before you can tell what rear end gears you have. Did you try checking your option codes in the glovebox? If those haven't been ripped out, you'll either have GU4 or GU5, being 2.73 and 3.23 respectively.
Old Jun 7, 2007 | 07:35 PM
95slvrZ28 is correct. GM put the 4L60E in Camaros starting in 94. The 700R4/4L60 (no E) was used in 93 and earlier cars. To put a 700R4 in your 96 car is not a straight in & out job. TV cables needs to be added, the thorottle body is different due to the extra cable, and the PCM need to be reprogrammed to avoid lighting the trouble lite. Don't cofuse the cruise control cable with the TV cable.
Old Jun 8, 2007 | 12:47 AM
1bad96Z28's Avatar
right thats what i thought. but someone said that idont know why but anywhoo. ill check that tomarrow.
MaVeN
Nov 24, 2010 03:04 AM
dogma
May 27, 2010 12:11 AM
j_reeves
Sep 26, 2009 10:00 PM
b1keslddr
Jan 28, 2007 11:44 PM
95 Z28
Mar 1, 2006 11:30 AM
