LT1/LT4 Tech 1993-1997
Problem when starting from a stop
Old Jul 18, 2010 | 12:22 AM
My30th's Avatar
Default Problem when starting from a stop
Hey everyone, got a problem I need help diagnosing. 5.7 automatic 1997
This does not happen all the time but it seems like its happening more often.
When the vehical is in drive and I let off the brake to go, i have something happening. It almost feels like the rear brakes are grabbing. I have a grinding/rubbing sensation coming from the rear of the car. It happens before i get on the gas as the car begins coasting forward. As soon as I get on the gas, it stops and everything acts normal. Two or three weeks ago i noticed this and my first though was geez there go the tranny. Now it is happening twice a day regardless of wether or not the vehical has been sitting or its hot from driving.
Im trying to stay positive and think its something small. Ive ordered new u joints and plan on installing next weekend hoping that this is the problem. Would u joints cause anything like this to happen? The transmisson fluid had good color and didnt smell burnt. Everything else that i know to look at has checked out fine.
Any ideas or thoughts? Has anyone else had a problem similar to this?
Thank you in advance for any help on this one.
Old Jul 18, 2010 | 12:27 AM
Ehhhhhh....since it feels like the rear brakes are hanging up, did you, oh gee I dunno...check the rear brakes maybe?
Old Jul 18, 2010 | 12:30 AM
My30th's Avatar
Yep they checked out fine. Was just trying to describe the sensation I feel when this happens.
Old Jul 18, 2010 | 12:32 AM
With the car parked, put it up on jack stands and trans in neutral. Step on the brakes, then get out and give the tires a light twirl and see if you can figure what the hang up is.
Also turn the driveshaft and feel for any resistance/slop/play.
Old Jul 18, 2010 | 08:27 AM
torque_is_good's Avatar
Im trying to stay positive and think its something small. Ive ordered new u joints and plan on installing next weekend hoping that this is the problem. Would u joints cause anything like this to happen? .
giving a rating of 1-10 with 10 being the highest probablility, I'd give it a 1 or 2
but new u joints aren't a bad thing and is an easy task
Daniel Fro Lozano
Aug 13, 2012 10:01 AM
Roscoep
May 12, 2011 10:32 AM
My30th
Jul 18, 2010 10:01 AM
White00ss
May 16, 2008 10:49 AM
Tenn Man
LS Series Tech
Nov 2, 2006 11:35 PM
