LT1/LT4 Tech 1993-1997
Passenger Side Turn Signal
Old Mar 21, 2011 | 06:32 AM
madmax32's Avatar
Default Passenger Side Turn Signal
Ok short story it BLINKS REALLY slow.
Ok what i've done replaced all lights (all meaning every light) Also spliced in new sockets.
Any clues to why? Oh and it blinked SLOW before I did the splicing.
Ive tried to locate the flasher relay but the only one i can find is the hazards. I can hear it but can't seem to find it (Bad hearing I can't judge distances or left and right due to working around aircraft but I can hear it lol)
any clues where the damn relay is Damn Chilton and Haynes manual are wrong. I don not have a convience panel under the dash the hazard relay was located near the left side of the steering Col the flasher sound seems to come from the right near the top of the Steering Col
1997 Z28 Vert A4,
Old Mar 21, 2011 | 09:51 AM
its on the other side of the columm
http://www.shbox.com/1/flashers.jpg
Old Mar 21, 2011 | 11:19 AM
madmax32's Avatar
Thanks Craby. Only problem is my under dash doesn't look like that and its all stock. I don't have a conv panel. I 'll look again tonight and i'm the only owner so I know nothing has been modified under there.
I found the hazard one near the Console above a metal bracket that the Steering Column connects to. You can barly even see that one. Only reason I found that one was due to the fact that I turned on the flashers and my hand was up near that area and I felt the clicking on and off.
Old Mar 21, 2011 | 08:58 PM
its there, did you take the cover off down there? look for two wires running into a red, plastic connector toward the front of the dash frame. that connector is what plugs into the flasher unit (which is completely hidden from view by the plastic dash-frame around it). pulling up on the connector will pull the flasher relay out of its compartment. it looks just about identical to the one for the hazard lights.
Old Mar 24, 2011 | 07:01 AM
madmax32's Avatar
Sorry this is so late but thank you I found it and replaced it. The relay was where you said it was.
AmericanMuscle1989
Oct 17, 2013 07:51 PM
JZ28
Mar 31, 2012 09:13 PM
Brayan99
Jul 23, 2011 06:59 PM
tirocz
82-92 V8 Tech
Mar 25, 2008 05:38 AM
DoubbleQue
Feb 20, 2008 06:47 PM
