Leaking under passenger side
Old Feb 11, 2008 | 10:14 PM
DoubbleQue's Avatar
Default Leaking under passenger side
Well i just finnished gutting all the plastic pannels out of my car, to start prepping for restoration, and i noticed under the dash on the passenger side close to the door theres water leaking. The foam thats in there is soaked and the carpet under the dash was wet.....what could this be from?
Old Feb 11, 2008 | 10:59 PM
350rs's Avatar
March 2008 ROTM
Default RE: Leaking under passenger side
t-tops leak a lot. Probably from that if it has them, if not, could just be a leak in the window.
also, what kind of shape is the heater core in? could very well be that
Old Feb 13, 2008 | 03:36 PM
dhighway's Avatar
I have the same problem! and from what ive read and heard, and seen for myself! it is the drain tubes for the T-TOPS they run down the rails and dump out behind the fender and the front of the doors, but i have yet to fix mine, it needs all new rubber thru out, and will be done this spring when it gets a complete paint job, good luck with it and let me know if its a pain to fix or is something else that is causing the wet carpet.
Old Feb 13, 2008 | 05:48 PM
DoubbleQue's Avatar
It has to be something else. mine aint a T-Top
Its really bugging me, i'm heading out right now to install a new CD deck i got (well used old crap one) just got it for something to listen to while i work on the car.
Anyways will check it out and see whats going on...if i can i dont know **** about cars.
Old Feb 13, 2008 | 06:12 PM
350rs's Avatar
March 2008 ROTM
sounds like it MIGHT be the weather seals around the window leaking on ya then. Check them out. are they at all rotted or torn or a crease somwhere it shouldnt be?
Old Feb 15, 2008 | 10:20 AM
age84's Avatar
March '09 ROTM
Check your heater core see if it is leaking unless it has been sitting for a while if you have been driving it up to this point i would also check the floor boards for small holes
Old Feb 15, 2008 | 10:26 AM
camaro1984's Avatar
yea it sure does sound like a heater core
Old Feb 15, 2008 | 04:54 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Does it smell like antifreeze at all?
Old Feb 15, 2008 | 05:20 PM
350rs's Avatar
March 2008 ROTM
you could always dip your finger in it, and dab it on your tounge, if it tastes bitter, its coolant. BTW,,, DO NOT SWALLOW THIS! spit it out.. lol
Old Feb 15, 2008 | 07:02 PM
August 2009 ROTM
The way I usually test this is by taking out the carpet, squeezing the liquid into a bowl, then give it to the neighbor's dog. If it dies, I know its the heater core. If not, you can look someplace else.
Btw for you people with no sense of humor, that was a joke.
