LT1/LT4 Tech 1993-1997
Oil Leak plz help
Old Mar 10, 2006 | 10:41 AM
cazador64's Avatar
Default Oil Leak plz help
I got a 1995 Z28 and it has a pretty bad oil leak coming from the rear of the engine. and from what i read there is a good chance its one of two things rear intake or rear main. now i do not think its the rear main because my y pipe is bone dry and i do not get any smoke. so was wounder if anyone know knew a good website that might tell me how to fix this problem like a repair guide or something. im pretty good with cars ive just never worked on a camaro ever.. Hope you guys can help me,..,
[IMG]local://upfiles/2455/5630F61DE43A4494BF45EC138C63C087.jpg[/IMG]
Old Mar 10, 2006 | 07:30 PM
94Z28SHAKER's Avatar
Default RE: Oil Leak plz help
its probably the intake manifold leak, im actually working on one today. here is the link you need
http://www.projecttransam.com/projects2.asp
Old Mar 10, 2006 | 07:31 PM
by the way make sure you get the steel fuel line disconnect, the nylon one's suck.
Old Mar 10, 2006 | 08:00 PM
Use your hand to feel behind the intake manifold where it meets the block. Feel the entire lenght. If you feel oil, then you found the leak.
Old Mar 10, 2006 | 11:00 PM
cazador64's Avatar
thats a great guide thanks alot !!!
Old Mar 13, 2006 | 01:22 AM
no prob, just did mine today again, make sure you buy the fel pro with the silver coating, the cork ones dont work that great,i could tell i was gettin a small amout of fuel contamination on my number 8 cylinder, make sure you get the permatex ultra copper too dont go with the red stuff, and dont do that thing with the pencils that he has as a tip in the guide, since the mounting holes are on an angle it will just make it harder. i took the time to also polish up my heads and intake manifold while i was at it, as well as the TB bypass. I will finish putting all the wires, and vacum line's on tomarrow after work, should be a big improvement.
Jelz28
Jul 18, 2012 06:01 PM
95mero
Jan 5, 2009 09:14 AM
derrickdiggler
Oct 12, 2007 01:22 AM
derrickdiggler
Sep 27, 2007 02:26 PM
daltons 1980
Sep 24, 2007 09:04 AM
