LT1/LT4 Tech 1993-1997
what engine should i use
Old Mar 5, 2006 | 03:48 PM
camarokid02747's Avatar
Default what engine should i use
wat engine should i put in my 97 rs so that i wll be runnin 11's and what other mods should i put with it.
Old Mar 5, 2006 | 04:13 PM
94Z28SHAKER's Avatar
Default RE: what engine should i use
something with around 475 hp/500tq, you would need to change your motor mounts, custom weld a lot of things, all new suspention, new rear end, new trans, the V6 camaro's suspention and other parts would not hold up to that much power, also you will need to build yourself a roll cage to put in if you plan on racing at the track, if you run faster than 11.5 they require one or you will get kicked out
Old Mar 9, 2006 | 02:59 PM
wat material should i use for the roll cage
Old Mar 10, 2006 | 09:42 PM
If u plan to run into the 11s, get yourself a rules book from the NHRA. There are many safety rules that you must meet for them to allow something that fast on the strip. You want to build it right the first time & save yourself time & money.
Old Mar 13, 2006 | 01:41 AM
first what he said^^^^^^^^^^^^^^^^^^^^ and as for the cage, somthing light but strong, and safe.
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
