LT1/LT4 Tech 1993-1997
Noob!! car runs hot lacks power and misses
Old Jun 8, 2010 | 10:10 PM
  #21
skywurz's Avatar
original issue but nolonger overheating
so far i got ballsy and frustrated and started disconecting injectors while the car was running i found that 6, 1 and 3 change very little when i dissconnect the injectors but when i rev its more noticeable. so im thinking pluged injectors? im at a compleate loss on this. the car starts right up and idles fine and revs ok it hesitates when you step on it and when you try to drive it. lets say you put it in first on flat ground let out the clutch and let it roll then step on it nothing happends its like a tractor it spools up slow i have no codes (i did get code 18 after fussing with injectors but cleard it) other than that no codes the o2 sensors seem to be reading in the same range
Old Jun 13, 2010 | 08:03 PM
  #22
skywurz's Avatar
Ok so i did a compression check and it looks ok. i then replaced the opti and started it up the miss seems to be gone but it is even more under powered than before. i did run out of gas in the driveway while running it vapor lock? Still no codes it seems to be running normal except no power and it takes forever to spool up when you step on it. Any ideas?
Old Jun 13, 2010 | 08:15 PM
  #23
check the fuel pressure.
Old Jun 13, 2010 | 08:16 PM
  #24
skywurz's Avatar
will do i will let you all know
Old Jun 13, 2010 | 08:21 PM
  #25
when was the fuel filter changed last? may be a good idea, if you do change it dump the contents into a clear container and see if theres crab in there,,, like rust or water.
Old Jun 13, 2010 | 08:41 PM
  #26
Oh cod, don't start with the crab stuffing again, it gives me a haddock!
Old Jun 13, 2010 | 09:14 PM
  #27
skywurz's Avatar
40psi on fuel system and it only drops to about 30 when I jump on it but it recovers quickly
Old Jun 13, 2010 | 11:24 PM
  #28
fuel pressure is good. test the tps and the map. the only thing i can think of is the computer is getting bad info from somewhere as you are accelerating. maybe pick up a noid light for your injectors and see if the flashing increases with rpms.
Old Jun 13, 2010 | 11:32 PM
  #29
skywurz's Avatar
i know tps is good and so is the map im not sure about the O2 how many volts should i be getting after it has sat overnight and has not run? but closed loop should out rule that issue. Im gonna try putting a coil booster on it tomarrow to see if its weak spark
Old Jun 13, 2010 | 11:52 PM
  #30
have the injectors checked. its not that much to have them cleaned, pressure and flow tested.
