LT1/LT4 Tech 1993-1997
Noob!! car runs hot lacks power and misses
Old May 30, 2010 | 06:43 PM
skywurz's Avatar
Default Noob!! car runs hot lacks power and misses
Hi guys i hope someone can help. I just got a 94 6peed. I just put this back together with rebuilt heads new timing set. it has a flow master cat back system and k&n intake. It had a new opti put in less than 6k ago. It starts ok and idles but it seems to do a little idle searching and if you step on it it misses and hesitates. when you drive down the road and let off of it, it makes popping sounds and its under powered and then it starts to get warm. I checked my spark plug wires and they are all right. I have checked and cleaned my maf, and the check engine light is not on. any other ideas?
Old May 30, 2010 | 06:58 PM
did u bleed the cooling system. a few times? has it been scanned for trouble codes?
Old May 30, 2010 | 07:01 PM
skywurz's Avatar
bled the cooling system but it has since puked out of the overflow. no it has not been scanned
Old May 30, 2010 | 07:16 PM
bleed again this time try parking on a hill with the front of the car up. when the motor is cold and off fill the radiator and open the beed screws till fluid comes out. the upper bleeder on the hose will not bleed without the motor running. once you get that done start it and this time bleed all the screws. close her up and take it for a ride around the block and take it back and do it again.
Old May 30, 2010 | 07:34 PM
skywurz's Avatar
ok i willl try that any ideas for the other issues?
Old May 30, 2010 | 07:36 PM
well if you got one of the cheap opti's then i would suspect the opti. best to scann for codes first. could save some major coin.
Old May 30, 2010 | 11:40 PM
skywurz's Avatar
The car has no hard codes but i will have to wait untill i get a cable for my pc befor i know more anything elce i can look at
Old May 31, 2010 | 05:32 AM
Size:  49.5 KBName:  P3170041_1.jpg
Old May 31, 2010 | 01:40 PM
rwing7486's Avatar
sounds to me like a timing issue and im guessing its the opti....same thing happened with me and it eventually started throwing codes
Old Jun 3, 2010 | 10:57 PM
skywurz's Avatar
pluged in my pc and no codes ran it for a bit it got warm and still runs ****ty and no codes. any one know of a better tool other than free scan that can lets say shut down each cylinder?
