LT1/LT4 Tech 1993-1997
Noob!! car runs hot lacks power and misses
Old Jun 3, 2010 | 11:08 PM
how did you set the lifters running or not?
Old Jun 3, 2010 | 11:15 PM
skywurz's Avatar
oh i do get lotts of power at high rpm like above 2500
Old Jun 3, 2010 | 11:21 PM
skywurz's Avatar
the lifters are what i too am wondering about i set them not running i did the #1 tdc then the exhaust and intake of the ones that where listed in the book. then i did tdc on 6 and did the last of them. i was worried that when i was tightening down the 3/4 turn the valve springs started to collapse but i read that they do that with used lifters and they will self adjust.
Old Jun 3, 2010 | 11:33 PM
try resetting them while its running, its not bad with the lt1, it doesnt squirt oil like the old sbc. gotta take the alternator out but its ok without the belt to set the valves.
Old Jun 4, 2010 | 12:44 AM
That two step static adjustment you did by the book is fine, AS LONG AS you intend to readjust the valves with the engine running method. As a set and run blanket adjustment, it sucks.
If you don't want to set the valves while running the engine, there are better ways to adjust them so that you get the lifters on the heel of the cam lobes, such as this way: Valve Adjustment
Old Jun 5, 2010 | 07:55 PM
skywurz's Avatar
ok so i re did the valves i tryed to do the running method but ended up ajusting the intake right as the exhaust started to open and such and they where all right.
This is where things got bad
It did not run any better after i got it all back together but it has stoped warming up i decided to try my hand at flashing my pcm to see if starting the cooling fans at a lower temp would help a little that all went fine and work i decided to flash back and as C.A.T.S. was connecting the cable got unpluged and now i think my PCM is fryed im looking for posts on this.
Old Jun 5, 2010 | 09:41 PM
good thing is you can still get an ecm for your yr.
Old Jun 7, 2010 | 12:52 AM
skywurz's Avatar
ok some things have come to mind i had to re wire a injector plug as i had one that was cracked is it possible to have wired it backwards dose it matter? and i think i need to check my injector wires and make sure that they are all sending signal to the injectors
Old Jun 8, 2010 | 08:47 AM
skywurz's Avatar
ok i have a new pcm and it starts and runs again
Old Jun 8, 2010 | 08:06 PM
  #20
Grandpaswagon's Avatar
So, are you back to the original problem? Or is it running correctly now?
