LT1/LT4 Tech 1993-1997
No Gas . . . Now No Start. Finally Done!
Old 12-06-2006, 06:49 PM
r.serio's Avatar
Default RE: No Gas . . . Now No Start.
Anyone have any knowledge on the Walpro 255LPG fuel pump? I just ordered one.
Old 12-06-2006, 07:35 PM
r.serio's Avatar
Also . . . Where is everyone getting thier 160 thermostats at? I can't find one anywhere.
TIA
Old 12-07-2006, 10:53 PM
aap94z's Avatar
the guys here are right its not hard to do the fuel pump just time consuming. it took me 3.5 hours with no lift. the only pain in the *** is that on mine (not sure bout yours) i had to lower the rear axel about 3-4 inches to squeeze the tank by. good luck.
Old 12-08-2006, 12:47 AM
chevyman81's Avatar
well when you do get you fuel pump changed out please let me know how long it takes becouse i have to do mine.... also this jumper you can use to test the pump could someone please let me know how you do this. thanks
Old 12-08-2006, 12:42 PM
The jumper sticks out of the passenger side wiring harness that goes to the front lights, runs ovrt the wheelhousing. There is a large harness with a smaller one coming out of it. The smaller harness has a large connector. Just before the connector there is a singke wire with nothing but a connector hanging on it. This wire goes directly to the fuel pump motor and it can be used as an extension for voltmeter leads. Connect the "+" lead to the connector, and the "-" lead to ground and you can measure the actual voltage at the pump. You can also connect a fused jumper between the "+" terminal on the battery and feed battery power directly to the pump.
Old 12-08-2006, 08:04 PM
r.serio's Avatar
Default RE: No Gas . . . Now No Start. Finally done!
Well, everything went kinda smooth. The tank is out and tomorrow it goes back together. I disconnected the bottom of the shcoks so the rear would drop enough to get the tank out. Like mentioned, just time consuming. Maybe not, I took more breaks than I should have. Removal=2.5 hrs.
That sucked . . . Had to drop the exhaust, disconnect the lower shocks. I should have sent it out. I'm asking santa for a lift for Christmas.
Old 12-11-2006, 04:56 PM
aap94z's Avatar
yeah it takes some time but itll be worth it when shes done.
Lakatrae
03-29-2014 10:59 AM
79projectZ28
06-23-2008 10:45 PM
rdb357
03-30-2008 08:25 AM
Quick Reply: No Gas . . . Now No Start. Finally Done!
