Next step?
Im about to install long tubes and 3 inch exhaust and am wondering what the next step is. I've been told cam, injectors, or throttle body. Any suggestions or particular order? And of course a tube when I'm done
Yeah, I would go with a good heads/cam package for what you want from Lloyd Elliot preferably, as well as a 58mm throttle body, ported and polished intake, and probably 30lb injectors. I would get the throttle body and p&p intake first considering they will be a lot cheaper than the heads and cam, but if you have no budget, then go all out in one shot. When all of that is done, go for either a PCMforless tune or dyno tune to top it off.
This is going to depend on your budget more than what order. Like Timmy said if you can afford it play with the top end all at once. But be careful not to over do everything, too big of a top end will shorten the life of the entire engine. Also if you get too bumpy of a cam you will need to up the TB and injectors. Mild cam you will be good to go with your current TB and injectors but anytime you mess with the internals you will want to have a tune done.
Massey
Massey
Yeah, i want to go mild cam. My car is my DD so im trying to go mild so I effect my mpg as little as possible. Whats the best way to get the tune? I really cant handle having a disabled car for a week.
LolVtech
02-17-2014 06:08 PM
