LT1/LT4 Tech 1993-1997
new member having issues with serpetine belt
Old Nov 26, 2012 | 07:29 AM
phxlt1's Avatar
Default new member having issues with serpetine belt
my 1994 lt1 camaro is shredding belts, and they are also squeeling
Old Nov 26, 2012 | 07:35 AM
Moved this to the 4th gen LT1 section where it belongs.
Remove the belt and check your pulleys. You may have one that's locking up, or one that has a worn bearing and isn't tracking straight or is wobbling, putting uneven wear on the belt.
Old Nov 26, 2012 | 08:03 AM
Cheeks's Avatar
August 2011 ROTM
have you put the belt on and looked at all the pullies to see which one is the issue? I'd start there
Old Nov 27, 2012 | 07:05 AM
jkeaton's Avatar
You will have to visually check to see which pulley is out of line or locked up and casusing the problem.
Old Nov 27, 2012 | 05:17 PM
Grandpaswagon's Avatar
Is the car new to you? Is this a new issue or one that you have had for a while? Is the car all stock, or has someone replaced pulley's or a component recently? I mention that because it is possible for a replacement part (alternator, power steering pump, idler pulley, etc) to have the wrong pulley on it. It would be rare, but some of the cheaper remanned units don't have the best QA.
Camarokid212
Nov 3, 2011 03:56 PM
bd92rs
Jun 11, 2011 07:26 AM
slong1958
82-92 V8 Tech
Aug 19, 2009 11:33 AM
Spartan66
Apr 5, 2008 09:01 PM
