serp belt to v belt conversion
Old Jun 9, 2011 | 06:01 AM
bd92rs's Avatar
Default serp belt to v belt conversion
is there any possible way to eliminate the gaudy factory serp belt setup on a 92 and use a v belt instead
fyi: reasons for asking are
i am building the car mainly for drag race use with very littile street use so all i'll be pulling are the alternator, p/s pump and water pump
and the engine i'll be using is a built 383 that's in an 80 berlinetta
thanks
Old Jun 9, 2011 | 11:47 AM
carguy68ssrs's Avatar
Piece of cake. Just take engine from Berlinetta and drop in your RS with all the v-belts that are allready on it
Why not get rid of P/S also if just mostly drag car??
Old Jun 9, 2011 | 11:49 AM
Your current serpentine drive water pump is reverse rotation, so be sure to use a clockwise pump for a v-belt application.
Old Jun 9, 2011 | 01:54 PM
bd92rs's Avatar
i was hoping it could be done because the water pump, alternator and p/s pump are all new on the berlinetta so that's why i wanted to sit evertthing in like it was
plus the berlinatta has a built th350 trans in it to boot
Old Jun 9, 2011 | 06:00 PM
microkid's Avatar
March 2011 ROTM
Technical User
the alt is mounted differently, so some alterations to the wiring will need to be done. if you are transferring everything over from the berlinetta, that will work. however if you plan on using the th350, it will not work unless you make or buy a crossmember to work with it, possibly a longer or different driveshaft, you will need a provision for the torque arm, and your speedometer wont work. if it is going to see any street use, you will need a working speedo
Old Jun 9, 2011 | 09:31 PM
bd92rs's Avatar
got everything worked out as far as crossmember and torque arm goes
and the speedometer i will be using all aftermarket gauges in a custom made cluster
Old Jun 10, 2011 | 05:27 PM
microkid's Avatar
March 2011 ROTM
Technical User
sounds like you know what you are doing then, thats good. have fun
Old Jun 11, 2011 | 07:26 AM
bd92rs's Avatar
thanks for the replies guys
just wanted to make sure about the belt setup before i ran into any surprises
DashingDaryl
May 10, 2012 05:47 PM
A2TURBO
70-81 V8 Tech
Dec 14, 2011 09:52 PM
dozier72
Apr 18, 2011 08:28 PM
Z28inAUS
Jan 10, 2011 01:00 AM
1980rscamaro619
Jul 20, 2010 04:42 PM
