LT1/LT4 Tech 1993-1997
My '95 Z28 has "Altitude Sickness"
Old Jun 11, 2019 | 07:49 PM
Mark D. Simmers's Avatar
Question My '95 Z28 has "Altitude Sickness"
OK...Here goes...To the best of my ability. My "Bone Stock" '95 Z28 LT1 w/ 460LE runs perfect "almost" anywhere I go. I live near Phoenix and only drive it on weekends. We do drives at lower elevations and the car performs flawlessly. For some reason, the 3 times we have taken it up to higher elevations, above 6,000 feet, it starts to sputter, then dies. Will attempt to restart and chugs like mad. Opened the gas cap and has had a huge vapor lock every time as well. After 10 minutes or so, car will restart and run again...so long as we are heading back to lower elevations. When I try to continue uphill...car does the same, almost immediately. I'll answer as many questions as I can...All help is greatly appreciated. Hope I explained this correctly. Also, Car shows no CEL when it starts to happen.🥴
Old Jun 12, 2019 | 03:34 AM
may be the tank vent valve is failing or plugged https://camaroforums.com/forum/lt1-l...-system-51219/
Old Jun 12, 2019 | 08:04 AM
Thank You...I'll look into that. Cleaning the MAF Sensor today. Looked pretty dirty.
cujeg1
Jul 10, 2011 05:05 AM
GRIFF
Mar 2, 2009 05:04 PM
DarkLotus006
Jan 7, 2008 11:29 AM
pbplya888
Dec 15, 2007 07:00 AM
golfvette
Nov 8, 2007 06:54 AM
