Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Fuel tank question(its a Toyota)
Old Mar 1, 2009 | 09:39 PM
GRIFF's Avatar
Default Fuel tank question(its a Toyota)
I have a 95 corola that I occasionally need to drive. It sits alot and the fuel tank rusted and I had it replaced. The car now builds pressure in the tank to the point that it starts to flood out the engine at low rpm, it starts to do it after about 20 minutes of driving. I unloosened the gas cap and the air comes whistling out If I leave the cap loose it runs fine I cant quite figure it out so if there are any ideas I would appreciate it...
Old Mar 2, 2009 | 04:29 PM
One of the lines going to the tank is a vent. And it sounds like your tank isn't venting. There might be a bend in the vent line, rust in the line, a crimped rubber hose connection, or your charcoal canister could be plugged.
Old Mar 2, 2009 | 05:04 PM
GRIFF's Avatar
It would vent through the charcoal canister I would guess, the tank vent lines and everything is new. I will check the charcoal canister. Thanks
old hoon
Nov 25, 2012 11:49 AM
CamaroGuard96
Aug 8, 2010 08:43 PM
Thoreau
Feb 21, 2009 10:59 PM
basssnake
Jun 29, 2008 05:28 PM
