LT1/LT4 Tech 1993-1997
More Transmission problems
Old May 1, 2011 | 10:59 PM
x01660's Avatar
The Mustang Hunter
Unhappy More Transmission problems
Vehicle: 1995 Z/28 M6 Convertible
I was going into an underground parking garage when I saw a friend of mine. I was already on the incline (pretty steep), so I put it in reverse and backed up. I got all sorts of smoke, from the tires, but I also smelled something different.
When I finished talking and drove down, I tried putting the car in reverse and it just kinda grinded. Almost like when you try to shift into 5th from 6th and you accidentally go into reverse and it kinda grinds...
I turned the car off, put in in reverse, started the car and let off the clutch. I heard some grinding noises so I put the clutch back in and turned the car off.
I also felt vibration in the clutch pedal...
Did I just ruin my reverse synchros?
I hope not...
x01660
Old May 2, 2011 | 07:08 AM
x01660's Avatar
The Mustang Hunter
Anyone? No? Maybe?
x01660
Old May 2, 2011 | 09:01 AM
sounds like you busted something. sorry i dont have anything on a m6.
Old May 2, 2011 | 10:52 AM
Sounds like you broke something inside, or maybe snapped your clutch disc? Do all the forward gears work fine?
Old May 2, 2011 | 02:26 PM
x01660's Avatar
The Mustang Hunter
Yes. All of the forward gears work fine. Though they are a little harder to get into gear. I am thinking that maybe I need to bleed the clutch.
Old May 2, 2011 | 09:12 PM
x01660's Avatar
The Mustang Hunter
So....
Clutch hydraulic system was a little low and I bled it with a buddy of mine...
My synchroniser rings are toast...
We can get the car to reverse if we turn it off, put in in reverse, then start the car. I can live with that for the time being.
Anyone got a T-56 they wanna sell?
x01660
Old May 2, 2011 | 09:22 PM
I'd be curious to pop it open and see what there is to see. What do you have to lose, if you're already looking at wanting to replace it.
Here's a T-56 service manual: http://www.ttcautomotive.com/English...ice_Manual.pdf
DavidJ1907
Nov 15, 2010 05:49 PM
mcgovern92
Jul 26, 2010 09:31 PM
Dolan52
70-81 V8 Tech
Oct 24, 2007 11:33 AM
hurley870
May 21, 2007 07:08 PM
z28ster
Dec 13, 2006 05:37 PM
