LT1/LT4 Tech 1993-1997
LT4 HOTCAM KIT
Old Dec 15, 2005 | 11:48 PM
HURSTLT1's Avatar
Default LT4 HOTCAM KIT
incase yall hadn't notice i'm bored with my lt1 now....any feedback on the lt4 hotcam kit?...and how much of pain it is to install...never done a cam on a v8 before
Old Dec 16, 2005 | 12:15 AM
Lee Willis's Avatar
Default RE: LT4 HOTCAM KIT
Depends on what "difficult" means to you. changing a cam is not super difficult, but its not like changing a water pump or a starter. A bit more difficult (maybe much more) than installing headers. if you aren't an experience mechanic and don't have lots of tools and a good workplace you might think about paying to have s hoip do it. Make sure you get the whole kit, with springs, retainers, whatever they recommend all with the cam.
Old Dec 16, 2005 | 09:21 PM
RatedZ's Avatar
If you aren't mechanically inclined, leave cam installs to the pros.
As far as the LT4 H/C setup, I have one sitting in my closet. I haven't gotten around to getting the install done because the motor hasn't blown up LOL! I can't think of any reason to do a swap when I have a motor that runs perfectly fine. I'm just waiting......
If you're looking for a real high horsepower car, you're going to be disappointed with the LT4 H/C kit. You'll get around 350-370 rwhp with the LT4 H/C kit; not much more. However, the LT4 H/C kit is a great kit for someone that just wants a little bit more power. With an LT4 H/C setup, you could probably run around a 12.70 in the 1/4.
Old Dec 17, 2005 | 11:24 PM
HURSTLT1's Avatar
i'm pretty confident i could do the install, but at the same time..if i screw up and float a valve or something harsh like that it's on me...if a reputible shop does it..then it's on them,which to me is extra money well spent....i was more curious about what the came can give....those rwhp that's with proper tunning with stock injectors, stock t.b. ?
Old Dec 18, 2005 | 03:19 AM
RatedZ's Avatar
ORIGINAL: HURSTLT1
Those numbers are pretty much on average for cars with the Hot Cam setup and all supporting mods; headers, cold air intake, exhaust, etc. I would go with a 52mm throttlebody with the Hot Cam kit. If you get a throttlebody that's too large, you will actually hinder performance.
Old Dec 19, 2005 | 12:29 AM
HURSTLT1's Avatar
what is the stock throttle body size?... yeah i know to big of a throttle will hinder performance...but thanks for your help and advice though..yall are helping me a lot
Old Dec 19, 2005 | 07:23 AM
RatedZ's Avatar
ORIGINAL: HURSTLT1
The stock throttlebody size on an LT1 F-body is 48mm.
And you're welcome. That's what we're here for; to help each other out. [sm=grinangel.gif]
Old Dec 23, 2005 | 01:48 AM
HURSTLT1's Avatar
ok then ..help me on this...why would my car not start when it is cold?....bad iat sensor...i sprayed it with some carb/choke cleaner on accident..also got some on the m.a.s i doubt that's what it is....
Old Dec 23, 2005 | 02:21 AM
A bad AIT sensor will cause hard starting, but more important would be the engine temperature sensor, because if it tells the computer that the engine is hot when instead it is cold, the mixture won't be enriched for a cold start. Hopefully, you did not mess up the wires in he MAF when you sprayed it. Also, make sure the fuel pump goes thrugh the prime cycle when the key is frst turned on.
Old Dec 23, 2005 | 12:18 PM
HURSTLT1's Avatar
yeah the pump primes....your not talking about the temerature sensor on the water pump are you...there is a block sensor??
imcdowel
Mar 1, 2010 05:21 PM
baseballer91
Jan 16, 2008 08:37 PM
1bad96Z28
Dec 10, 2007 09:11 AM
Veritas
Oct 12, 2007 02:34 AM
gotalcoholmanup
Jun 14, 2006 08:48 PM
