LT1/LT4 Tech 1993-1997
LT1 Mods...
Old Dec 15, 2006 | 12:20 PM
Isphius's Avatar
Default LT1 Mods...
Ok, Im definatley getting an LT1 camaro or pontiac soon, And just have a few questions for the knowledgeable people. Do these cars respon well the intake manifolds, cams, headers, full exhausdt, etc as well as the 3rd gen 305s do? Like how much power could i expect out of just a full header dual exhaust and an intake manifold with cold air set up? And then if i went a step further and got the lt4 heads and cam and all that? Any help aprreciated, thanks/ Oh and another question, Can the 98+ style trans am nose be swapped onto a 93-97 that anyone knows of? They look pretty similar. Thanks.
Old Dec 15, 2006 | 02:39 PM
1070ryan's Avatar
Default RE: LT1 Mods...
You could probably expect to get about 325 hp. Cause stock you have 275. New exhuast (headers + cat back w/ high flow cats) would give you maybe 35hp. New intake maifold... maybe 15, and cai would give you maybe 5hp. So around 325-330. I am in the same position as you. I am in the buying stage for an LT1 Z28.... What i have heard is that you should just port and polish the intake and heads, and get the GM Hot cam kit (LT4). That should give you, along with exhaust, about 370-390 hp. PLUS--- It would cost less and give you more hp.
HOT CAM KIT -
http://www.gmpartsdirect.com/results...ow=11&pkgid=42
(At Bottom!!)
Old Dec 15, 2006 | 07:27 PM
95slvrZ28's Avatar
Ya, don't bother with purchasing a new intake or heads unless you're tryin' to push some crazy amounts of power. Get them ported and polished at a reputable place and they'll support at least 500 hp or so...
Old Dec 25, 2006 | 02:42 PM
Afrothunderr86's Avatar
you can swap the fronts but you will need more than just the bumper cover. you will need both fenders and the hood and headlights. it will all bolttogetherwith no mods.
briansmyhero
LS Series Tech
May 1, 2009 06:36 AM
1Slo_Camaro
Nov 26, 2007 11:25 AM
xXxSLPZ28xXx
LS Series Tech
10
Feb 9, 2007 10:41 PM
SteveO87
Feb 5, 2007 01:34 AM
KoRN_Munky
Jan 22, 2007 08:01 PM
