LT1/LT4 Tech 1993-1997
LT1 intake
Old Dec 25, 2006 | 09:21 PM
carguylt1's Avatar
Default LT1 intake
I would like to know how to gasket match the intake manifold. I have the tools with alittle knowledge" I seen it on T.V." All I need to realy know is how much tocut offand where to cut it? Iplaned on using theold gaskets as a teplate.
Old Dec 25, 2006 | 11:31 PM
Default RE: LT1 intake
Get a new itake manifold gasket, place it where it is supposed to go on the manifold and scribe a line around the edge of the gasket, and open up the port to meet the line. Do the same on the head side. You must do both the manifold and the heads otherwise you wind up losing power rather than increasing it. Even if done right, do not expect any great power gains, as the castings are pretty accurate from the factory, and the amount of material you are going to remove is not going to make much of a difference either.
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
antbradley100
Mar 12, 2011 05:11 AM
tuletymeZ28
LS Series Tech
Aug 22, 2010 12:12 PM
z28rob18
Jun 22, 2009 04:40 PM
