LT1/LT4 Tech 1993-1997
LT1 heads
Old Mar 8, 2011 | 10:55 PM
1998camarossclone's Avatar
Default LT1 heads
ok guys i got a problem i got a miss on cylinder 1. did a compression check and im only getting 40 psi. can the valves in a cast iron LT1 head work in the aluminum heads?
Old Mar 9, 2011 | 06:49 PM
Grandpaswagon's Avatar
What makes you think that you have a bad valve? Did you perform a leak-down test?
Old Mar 10, 2011 | 09:02 PM
im not sure if they are the same or not. i looked and cant find anything on it.
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
