LT1/LT4 Tech 1993-1997
lt1 heads
Old Jan 15, 2009 | 11:57 PM
350rs's Avatar
March 2008 ROTM
Default lt1 heads
considering a lt1 or an ls1 swap into the camaro instead of the TPI i was going to use. anyway. im wondering what heads will work on the LT1? do they HAVE to be designed for that block or can any SBC head work? If they have to be for the LT... whats a GOOD flowing semi high compression head i could use?
Old Jan 16, 2009 | 12:46 AM
95slvrZ28's Avatar
Well...technically any SBC head is going to bolt up, that said you're going to want to use a head that's made for the LT1 to get it to match the intake correctly. If you're looking strictly for an aftermarket head I would recommend going with AFR, it's hard to lose with them. They're a little pricey, but the quality is amazing and they have great mid-lift numbers. If you already have a set of LT1 heads most of us will recommend getting the stock heads worked over as well as a cam. If you're looking for just head work check out www.totalengineairflow.com or www.advancedinductions.com if you're willing to shell out a little more cash and get a whole top end check out www.dragonrace.com or http://www.elliottsportworks.com/
Old Jan 16, 2009 | 09:24 AM
350rs's Avatar
March 2008 ROTM
well lucky for me i didnt ask if they would bolt up, but if it would work. never heard of the LE engines mentioned in elliott's page
Old Jan 16, 2009 | 11:21 AM
whammer3024's Avatar
ROTM Winner
LE 1-3 just means the stage of porting he does. its not a complete engine. he would port and polish your heads and match a cam to suit your needs and wants. if you do much research you will find a lot of people that use his stuff. i will be in the future as well
Old Jan 16, 2009 | 11:44 AM
robmnrd's Avatar
What whammer said. (I know this post doesn't help much, but Elliot is good stuff.)
Old Jan 17, 2009 | 07:54 AM
z28rob18's Avatar
if your buyin a set of new heads id look at total engine airflow cnc'd trickflow heads or at advanced induction trickflows. but if your goin to get the stockers ported lloyd and AI are great AI is a bit more but they have some insane setups. they hav a customer with there 200cc heads that ran 9.86 on a mild HR and a 150 shot on the stock bottom end. ive looked into both and i think lloyds great but for wat im doin im using advanced inductions
Old Jan 17, 2009 | 11:34 AM
outta_control_z28's Avatar
yea i went with ai like rob said he has some nasty top end packadges that put out some tire ripping numbers !!
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
