LT1/LT4 Tech 1993-1997
Lt1 engine questions
Old Jan 25, 2010 | 01:43 PM
Cblaze's Avatar
Default Lt1 engine questions
I own a 3rd gen right now but am considering a lt1 six speed in the next few months.i do not know to much about the lt1 engine but i want to.since they run cooler what compression do they run at stock and what could one run at with aluminum heads on 93 octane.also what will the rotating assembley take?
Old Jan 26, 2010 | 09:22 AM
stock lt1 is 10.5 to 1 and 11 to 1 would be ok. it all depends on the motor some will take 500 hp and not blow and some 400hp motors will blow. no way of knowing until u do it. i would say 400hp is a safe number for a 2 bolt lt1 and 450 is doable. the real issue is hooking up.
Old Jan 26, 2010 | 04:30 PM
dc14u2no's Avatar
PS,By the way...most lt-1's(at least camaro's)have aluminum heads.Except impala,buick,cadilac etc.And generally an lt-1 runs a lil hotter.Reverse flowing coolant!!!
Old Jan 26, 2010 | 08:29 PM
z28rob18's Avatar
the highest compression you could do on 93 is about 12:1 a few ppl run it i was gonna but went 11:6.1
Old Jan 27, 2010 | 11:57 AM
ESPxCONxXx's Avatar
i run 11:1, on 93 with stock ported heads
SMatyac
May 1, 2012 02:45 PM
sam24th
Jan 8, 2011 06:40 PM
james hellsing
May 11, 2010 10:56 PM
kyphur
Dec 20, 2007 09:39 PM
sullym47
Mar 29, 2005 03:04 AM
