LT1/LT4 Tech 1993-1997
Ignition Module
Old Nov 23, 2010 | 06:44 PM
JordanN's Avatar
Default Ignition Module
On my brothers 93 Z28, his ignition modules keep burning up. We've tried the spacer trick but they all end up burning up. What could cause this?
Jordan
Old Nov 23, 2010 | 08:48 PM
VALHAR's Avatar
If you put it in correctly, don't forget to use the module jell and check your voltage.
Old Nov 23, 2010 | 09:24 PM
yep gotta have that heat sink paste.
http://www.radioshack.com/product/in...ductId=2526910
Old Nov 23, 2010 | 09:35 PM
make sure the ground is not lose. there is a ground wire coming out of the wire harness that goes to the ignition module and should be connected on the front of the motor just below the module. either on the head or the block. there is also a tach module that hooks into the ignition module. check the wires to it for any damage. its a square box taped to the wire harness.
Camaroboi22
Feb 2, 2013 09:29 AM
UFGatorFan
Jun 6, 2012 02:58 PM
CNCman
Nov 2, 2009 11:21 AM
camarofreak1990
Oct 8, 2008 02:29 PM
94Z28SHAKER
Nov 13, 2007 05:36 PM
