LT1/LT4 Tech 1993-1997
i think i hate this car
Old Aug 25, 2011 | 02:04 PM
  #31
BasicConcepts's Avatar
Technical User
i think i found the sound... thinking its in the trans i pulled it but now the flexplate is smacking against the starter i looks like its got wicked bend in it
how many teeth are on the flexplate???
Old Aug 25, 2011 | 03:15 PM
  #32
the lt1 spits oil out of the rockers, i thought something was wrong with mine when i first seen that and asked a few people about it, the amount of oil the lt1 puts out of the rockers is way less than a old sbc. maybe the flexplate is the problem or the trans has caused the flexplate to bend. i would try a new flexplate first. 153 tooth. forget what the converter pattern is
Old Aug 25, 2011 | 03:28 PM
  #33
Technical User
Got the flexplate ill have to wait till tomorrow to install it I gotta go to work
Old Aug 25, 2011 | 07:46 PM
  #34
Grandpaswagon's Avatar
I wonder what would cause the flexplate to warp? I've never seen one warp after being installed. I have seen them get bent when knocked off the work bench though. But never one warp after installation.
Old Aug 25, 2011 | 08:29 PM
  #35
Technical User
idk but it looks like a pringle lol
Old Aug 25, 2011 | 10:23 PM
  #36
One way to warp the flexplate is if you thought the torque converter was seated fully onto the input collars of the trans pump, but it wasn't. Then cranking the bellhousing against the block would be tweaking against the flexplate since there isn't any fore and aft clearance like there should be. That's the reason I asked if there was clearance between the t.c. and the flexplate after it was unbolted.
Old Aug 26, 2011 | 11:04 AM
  #37
Technical User
so the flexplate isnt warped or bent somehow one of the weights broke off and threw it out of balance GHEYYYYYYYYYYYYYYYYYYY
Old Aug 26, 2011 | 11:17 AM
  #38
Oh man....but that's a good thing!
Old Aug 26, 2011 | 11:27 AM
  #39
That is not as uncommon as you might think. I have seen the weights coming lose on atleast 4 seprate times. One of those times I was replacing a cracked flex plate and when engine started it made a heck of a noise. The weight was hitting the engine block. One of the spot welds did not hold. Redo. I check every flex plate since.
Old Aug 26, 2011 | 11:53 AM
  #40
Technical User
well i replaced the flexplate and guess what... still f****d so now my dilemma is do i tear into the motor again or sell the car as is
