LT1/LT4 Tech 1993-1997
i think i hate this car
Old Aug 24, 2011 | 04:44 PM
  #21
K, well that blows that theory then.
Old Aug 24, 2011 | 04:50 PM
  #22
BasicConcepts's Avatar
Technical User
I'm going to try to hold it with something
Old Aug 24, 2011 | 04:59 PM
  #23
Grandpaswagon's Avatar
Be very careful then. If whatever you are trying to hold it with gets wedged between the flexplate and TC, then it will start rotating and could cause a fair amount of damage or seriously injure you.
Old Aug 24, 2011 | 05:18 PM
  #24
Technical User
i think im gonna loosen the trans and slide it back a bit seems a little safer
Old Aug 24, 2011 | 05:27 PM
  #25
Push it as far back as you can.
Old Aug 24, 2011 | 05:38 PM
  #26
I an not a LT1 expert but why is there no oil shooting out of the rockers? With no oil deflecting clips installed you should have a heck of a mess. There should be oil hitting the inner fenders.
Old Aug 24, 2011 | 05:48 PM
  #27
I've seen small block do it both ways. Shoot oil clear of the fenders and just a steady stream running over the lifters.
Old Aug 24, 2011 | 05:59 PM
  #28
Technical User
it was more running over the rockers a little came out of the head onto the manifolds but not too bad... anyways i drained the oil and ran a magnet through it absolutely no metal in the oil
Old Aug 24, 2011 | 06:53 PM
  #29
Are you sure you have good oil pressure? Try dipping a pc a paper towel into the oil and look at it with a magnifying glass. With an old school SBC that amount of oil coming out of the lifters would be a problem. The oil should be splashing around a lot. That oil is the only cooling the valves have.
Old Aug 24, 2011 | 07:09 PM
  #30
Technical User
Its not exploding out of the rockers but its deff flowing good oil pressure is where it always is about 1/4 at idle and jumps to about 1/2 with throttle
i used a piece of paper as my paper towels have wicked texture but still the oil looks good a few specks of metal but no chunks (kinda made me think someone put glitter in the oil)
