LT1/LT4 Tech 1993-1997
I got a small problem
Old Feb 24, 2006 | 12:11 AM
LT1Sergio's Avatar
Default I got a small problem
I have a problem. My Lt1 doesn't seem to run 100%. Since I've had it it's always had a small misfire. I've changed the plugs, wires, and add a bottle of injection cleaner, but it still does it. It seems like it's getting worse. What could it be? The only thing I can think of is that the ignition coil is going bad or the distributor is going bad. I don't think its the injectors. But I will check the fuel pressure ASAP. I'm new to these engines but can someone help me?
Old Feb 24, 2006 | 02:22 AM
Default RE: I got a small problem
If the coild does not help, then it may well be the optispark. Check all wiring & connectors bewtween opti, coil, and ignition module, they have a habit of getting corroded which results in weird misfires. Is the SES lite lit??
Old Feb 24, 2006 | 08:16 PM
94Z28SHAKER's Avatar
yea, new blaster coil, and MSD 6AL cured that problem for me, and also gave me much more throttle response
Old Feb 25, 2006 | 11:11 PM
LT1Sergio's Avatar
Yeah, I was gonna ask about that. I want to get the MSD 6AL box but I can't find the wiring harness for the LT1. Accel sells the entire kit (ignition box, coil, and wiring harness) for the LT1. But I'm not too crazy[:'(] about Accel.
Old Feb 28, 2006 | 06:50 PM
I would try to stay away from Accel coils. Had them on two different cars, and both coils died, replaced them with the original stock coils & no more problems.
tontig190
Jan 11, 2012 01:52 PM
mrblock2013
Dec 25, 2011 08:47 AM
danlindquist1990
May 2, 2010 09:15 AM
Bowtie Or No Tie
Jun 22, 2008 12:58 AM
slowZ
Mar 31, 2008 02:49 PM
