LT1/LT4 Tech 1993-1997
hydrualic lifters
Old Nov 29, 2006 | 07:54 PM
KoRN_Munky's Avatar
Default hydrualic lifters
how many RPM's can the STOCK 1997 LT1 hydrualic roller lifters take? another thing i heard only vette lt1's are 4 bolt mains but is it possible that some camaro ones could be 4 bolt. and how many rpms can the comp cams 1:6 pro magnum roller rockers take for RPMs?
Old Nov 29, 2006 | 08:07 PM
94Z28SHAKER's Avatar
Default RE: hydrualic lifters
stock lifters with low miles can see up to 6500 rpm's safely
i dont think that vette LT1's have 4 bolt mains, but the Corvette grand sport LT4's do.
the comp cams 1.6 pro magnum roller rockers assuming they are non self aligning with guideplates, hardened pushrods can see up to 6800- rpms safely with correct prings, and up to 7,000 rpm's with a hydra rev kit,
the magnum self aligning rockers can see up to 6200 rpm's safely, but i wouldnt go much higher for too long, or the rocker fulcrum might jump off the spring cap.
Old Nov 29, 2006 | 11:24 PM
KoRN_Munky's Avatar
http://www.automotiverebuilder.com/ar/ar99928.htm
well on that under blocks it says about 2 and 4 bolt mains. i don't have hardend pushrods they are stock, stock springs, and actually i double checked i guess i only have just the comp cams 1:6 magnum roller rockers part # 1416-16 on comp cams. i have my shift points at 6000 1-2 6020 2-3 and 5920 3-4 rev limiter is set at 6300 too. so should i be ok? rest of the valvetrain has 94010 miles on it. oh and what is the crank made out of on the lt1?
Old Nov 29, 2006 | 11:28 PM
KoRN_Munky's Avatar
xPBxWrEckeD
82-92 V8 Tech
Nov 4, 2007 06:41 PM
libertyforall1776
Oct 8, 2007 12:05 PM
thebandit110
Jun 30, 2007 12:32 AM
snake10556
Jun 24, 2007 04:04 PM
mike sel
Apr 14, 2004 08:54 AM
