lifters
Old Jun 29, 2007 | 11:44 PM
thebandit110's Avatar
Default lifters
if i put regular style lifters, and roller rockers in. will the oe style lifters cancel out the roller rockers??? or should i just save the green and get both roller lifters & rockers???
Old Jun 30, 2007 | 12:32 AM
Jesse7071's Avatar
Default RE: lifters
Switching to roller lifters is more complex than just dropping them in. You do not put roller lifters on a OE hydraulic cam for starters. If you go with roller rockers, it will decreasestress on the, rocker studs, valves, and pushrods. If you have to change something, just go with the rocker arms.
If you want roller lifters, you will need to start with the install of a roller cam. Then work your way through the valve train. Be prepared to spend a lot more than the 350 for lifters.
Todd78
70-81 V8 Tech
Jul 22, 2009 06:51 PM
r6rider
Jul 9, 2009 12:13 PM
libertyforall1776
Oct 8, 2007 12:05 PM
snake10556
Jun 24, 2007 04:04 PM
mike sel
Apr 14, 2004 08:54 AM
