LT1/LT4 Tech 1993-1997
Hydraulic Clutch Bleeding
Old Sep 26, 2007 | 11:21 AM
cdcamaro's Avatar
Default Hydraulic Clutch Bleeding
I went to go start the 383 I just put in my 95 Z28 Camaro for the first time and when I pushed the clutch in I broke the slave cylinder that accurates the fork that moves the throw out bearing. The first time I pushed the clutch in it went straight to the floor, the second time I pushed it in it go really stiff and I heard a loud snap (the slave cylinder breaking of the studs). I must not have had the fork in right on the throw out bearing and it slipped out of place. When I pushed in the clutch the slave cylinder jammed it against the side of the transmission case breaking the slave cylinders mounts in the process. I have ordered a new slave cylinder but I’m a little confused on how to bleed the system after I install it. Does anyone have any experience on bleeding this system?
bohuntr
Oct 22, 2009 02:49 AM
mpvette
Aug 28, 2009 08:04 AM
slpcamaro
Feb 19, 2008 06:34 PM
jml317
82-92 V8 Tech
Oct 24, 2007 09:39 PM
Justin_97_CamaroSS
Oct 8, 2007 02:32 PM
