LT1/LT4 Tech 1993-1997
how hard is it to install an intake fuel pump?
Old Sep 2, 2010 | 05:18 PM
critt86's Avatar
ok the pump finally came in the mail. I'm gonna go with the cuttin the hatch method needless to say. When i pull the pump out is it gonna be just a direct parts replacement, ( I mean a no brainer) or is there some crazy certain steps that need to be taken?
Old Sep 2, 2010 | 06:09 PM
Chaotic94's Avatar
September 2011 ROTM
Should be direct bolt on application. Unscrew all the old stuff. Screw in all the new. Call it good lol
Old Sep 2, 2010 | 07:07 PM
critt86's Avatar
well i certainly hope so...
Old Sep 2, 2010 | 07:46 PM
Crab Man, can you make a separate thread with the procedure and a the picture with the hole dimensions. I will make it a sticky as it seems this is a very common question. Thanx
Old Sep 3, 2010 | 06:31 PM
critt86's Avatar
ok well i cut out the opening to craby's specs in the picture. but I could not get the pump out. it keeps hitting the hole that its droped down it. any suggestions?
Old Sep 4, 2010 | 09:49 AM
critt86's Avatar
any one?
Old Sep 4, 2010 | 09:55 AM
so its hitting the body or the tank? you may want to losen the tank so it will drop a little or make the hole a little bigger. ive seen some were it was closer to the front edge.
Old Sep 4, 2010 | 10:15 AM
ok heres a couple good links for this. i like the first one better. the second one is sloppy and really doesnt show how the guy sealed up the hole.
http://www.fastbird93.com/Installations/Racetronix.htm
http://www.cardomain.com/ride/348183/9
Old Sep 4, 2010 | 12:07 PM
heres what i have so far. i will continue to look for better stuff and when i change mine again (hope not for a long time) ill take lots of pictures and do a write up if needed.
https://camaroforums.com/forum/showthread.php?t=54911
Old Sep 4, 2010 | 04:02 PM
  #20
critt86's Avatar
ok i just got finished doing it. my problem was i had to take out the lines before i could take out the pump. then i cut a piece of sheet medal then screwed and siliconed it over the hole i cut.
Berlinetta
82-92 V8 Tech
Nov 9, 2011 11:06 AM
jpepper
Apr 5, 2008 12:43 AM
libertyforall1776
Oct 17, 2007 12:22 AM
BlueKitsune
Oct 5, 2007 07:54 PM
broozer
Jun 29, 2007 10:25 PM
