LT1/LT4 Tech 1993-1997
high water temp
Old Nov 22, 2007 | 02:45 PM
95camz28's Avatar
Banned
Default high water temp
i just did a head gasket job and got them shaved downon my lt1 and the car hasnt been started since the day before and when i start it the water is instantly hot in 30 seconds why?
Old Nov 22, 2007 | 03:41 PM
Default RE: high water temp
Did you fill and purge the air out of the cooling system completely?
Old Nov 22, 2007 | 08:21 PM
95camz28's Avatar
Banned
yes i did wht do u think it is?
Old Nov 22, 2007 | 08:29 PM
02StanGT's Avatar
Is your water really hot? Or is that just what the gauge indicates? You have to put out quite a bit of energy to heat that much water, that hot, that quick. I think you ECT sensor is going crazy.
Old Nov 22, 2007 | 09:16 PM
As 02Stang said, it is pretty hard to get everything that hot so quickly. Run the engine with the radiator cap off, if you have a real overheating condition the coolant will boil out of the radiator. If not then it could be a bad ECT, bad gage, or a wiring problem. If it is actually overheating it could be a water pump problem, such as a missing drive shaft, or a head gasket blocking water passages. Hard to tell for sure from a distance.
Old Nov 23, 2007 | 07:40 AM
95camz28's Avatar
Banned
no i'm talkin about when i start it i have the radiator cap off and as soon as i start it i feel the water and in 30 seconds its very hot
sm515
Apr 27, 2014 01:27 PM
SB60
Jan 11, 2012 01:04 PM
Cammy
Jan 7, 2012 12:30 PM
gr8cars1
Jun 9, 2007 08:54 PM
chas
Apr 7, 2006 10:08 PM
