Car goes to high temp!
Old Jan 3, 2012 | 10:45 AM
Cammy's Avatar
Default Car goes to high temp!
whats causing my car to go to high temp.. it does it when i come to a stop.(min or two) or just letting the car heat up. and it will go back down when i start driving again. thanks.
Old Jan 3, 2012 | 10:49 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I believe the fans are set to kick on at 215* or something high. Should be normal as long as the car isn't overheating.
Old Jan 3, 2012 | 12:22 PM
BasicConcepts's Avatar
Technical User
try a coolant flush and a new tstat 195* that should help (normal opp temp is about 1/2 way up the gauge)
Old Jan 3, 2012 | 10:47 PM
AboveTheLogic's Avatar
If its been a while since the coolant has been flushed, definitely do that. Don't forget to bleed it with the bleeder screws.
I installed the fan switches from shbox's site and kick them on when hitting traffic, I like to keep my temp gauge below half whenever possible. Works well for me. As socom said, the fans kick on at a fairly high temp- and when they first kick on, they're running at low, not high.
Old Jan 5, 2012 | 05:14 PM
Cammy's Avatar
thanks all! ill see to it.
Old Jan 5, 2012 | 09:54 PM
RFxCamaro's Avatar
You should check if you still have your wind deflector for the radiator.
Old Jan 6, 2012 | 07:06 PM
androzer's Avatar
Default nice!
what is the piece look like? may u show us?
Old Jan 7, 2012 | 07:09 AM
Catmaigne's Avatar
The deflector is the black plastic chin that sits under the front bumper and directs air upward to the radiator. I doubt the deflector was removed because the car heats up at idle and cools when moving. Also, it's not overheating unless it goes into the danger zone. The factory fan presets are pretty hot.
Old Jan 7, 2012 | 12:30 PM
RFxCamaro's Avatar
Yea so at low speeds its not getting enough air. At high speeds it gets plenty of air so it doesnt overheat. If im not mistaken somebody was experiencing the same problem here because of the deflector.
Dirk88
Aug 20, 2012 06:42 PM
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
69flamedss
67-69 V8 Tech
May 23, 2011 10:30 PM
Turbolag86
Jun 10, 2010 02:30 PM
95camz28
Nov 23, 2007 07:40 AM
