LT1/LT4 Tech 1993-1997
High Idle
Old Apr 16, 2012 | 10:14 PM
BasicConcepts's Avatar
Technical User
As long as the leak is before the maf you'll be ok
Old Apr 16, 2012 | 10:53 PM
93 z28 does not have a maf. only map.
Old Apr 17, 2012 | 12:49 PM
MKCoconuts's Avatar
Headers were installed back in December. Just started doing this recently. I'm not too worried about because like I said, only does it in Park and Neutral. I'll clean and check the TPS when I come home this weekend. Header gasket doesn't sound like it's leaking...but hard to tell because the rockers tick a bit.
Old Apr 17, 2012 | 04:42 PM
iac idle air control valve/motor is what gets dirty. its under the tps.
Old Apr 17, 2012 | 05:41 PM
MKCoconuts's Avatar
All right. I'll clean that out too. Might just take the whole TB off and give it a good cleaning.
Old Apr 17, 2012 | 10:12 PM
its way easier to get the iac out with the tb out. im not sure it will come out otherwise. dont get carried away on the tb inside,,, where the butterflys touch, some tb will have a slitely textured or coated looking area there that keeps the butterfly from sticking against the walls. anyways yeh get all the crud outa there. check the intake manifold bolts for tightness. they dont torque out that much and over time and or running hot a time or two the gasket can colapse leaving the bolts lose. with new gasket the torque specs are 35ftlbs so again just check to make sure there not lose. check at the front seal of the intake to see if your losing oil there, common failure point on the lt1. rear is more so. heck pick up some injector o rings and put them on as well. need 16 if you do upper and lower o rings. very inexpensive.
Old Apr 18, 2012 | 08:00 AM
MKCoconuts's Avatar
Thanks Craby. As far as leaking oil, last time I checked it was good in all spots but will check again. I have a extra TB gasket at home so might as well take it off and clean it up some. I just don't like the stupid paint job the PO attempted to do any ways.
r00tk1ll
Feb 6, 2015 10:25 PM
kblood
Nov 5, 2013 10:44 AM
Mjbutz
Jul 13, 2013 10:15 PM
94z28chevy
Sep 17, 2011 09:08 PM
3.4CamaroCDOG
Mar 25, 2008 06:26 PM
