High Idle help plz
Old Feb 13, 2008 | 12:05 PM
3.4CamaroCDOG's Avatar
Default High Idle help plz
I changed the IAC and TPS and intake air temp sensor but im still getiin a high idle
i checked for vacuum leaks by spraying and i checked the throttle body connection by sprayin
it starts up at 1100 and then as it warms up it goes to 1500-1600 then stays
its hard to stop while in drive cause the wheels are still spinnin
ive tried everything and searched all the post im lost
could it be sumthin transmission wise?
wat else could cause a high idle?
Old Feb 13, 2008 | 04:42 PM
02StanGT's Avatar
Default RE: High Idle help plz
There is a screw on the throttle body by the linkage. When throttle is closed the linkage rests on this screw. If improperly set, it could keep the throttle open a little. Something easy to check.
Old Feb 14, 2008 | 11:53 AM
is it on the right side of the the throttle body? near the acceleration spring? and lever thing u pull to get to WOT?
i discovered something to
i lost one of the two fuses to the Fuel injectors under the hood and it idled normal but it didnt drive normally because it only had half the injectors workin
could it be idlin too high cause im gettin too much fuel? if so how can i adjust it?
Old Feb 14, 2008 | 12:22 PM
02StanGT's Avatar
Yes, the "lever" thing. I'm not sure what side it's on, on the 3.4. On my 3.8 it's on the right side. When the throttle is closed, the "lever" thing rests on thisscrew.
Old Feb 14, 2008 | 12:24 PM
aw ima look at it when i get home
i kno its a bolt by the acceleration lever but i dont see its purpose cause i think i tried moving it mayb its one im missing ill look again.
Old Feb 14, 2008 | 07:33 PM
ok i adjusted it and nuthin
its like the car is gettin too much fuel
my MPG is horrible
could a bad MAP sensor cause this?
Old Mar 25, 2008 | 04:44 PM
94jivvity's Avatar
Should the throttle body be all the way closed when it's idleing? (which would logically explain an Idle air control valve) Or should it be open just a little?
Old Mar 25, 2008 | 06:26 PM
02StanGT's Avatar
Should be full closed.
r00tk1ll
Feb 6, 2015 10:25 PM
kblood
Nov 5, 2013 10:44 AM
Mjbutz
Jul 13, 2013 10:15 PM
94z28chevy
Sep 17, 2011 09:08 PM
mikem290
Dec 27, 2007 01:38 PM
