LT1/LT4 Tech 1993-1997
Motor Question???????????
Old Apr 18, 2012 | 01:07 PM
Camaroboi22's Avatar
Question Motor Question???????????
Have a 94 Lt1 and I got another motor which is a 96 or 97 lt1 motor is there any sensors or parts that i have to change?
Old Apr 18, 2012 | 01:21 PM
BasicConcepts's Avatar
Technical User
Nope I put a 97 lt1 in my 94 with no issues
Old Apr 18, 2012 | 01:28 PM
so all the sensors are the same?
Old Apr 18, 2012 | 01:32 PM
Depends on which direction you're going with the years. Starting in 96, the LT1 has a separate crank sensor, the 95 and older doesn't have it. Putting an older LT1 in a 96 and newer car, without changing the timing cover to add the sensor, will render that part of the system's diagnostic inoperative and trip the check engine light.
Old Apr 18, 2012 | 01:49 PM
well rite now its just bare block so i am buying all new sensors so basically should i be buying sensor that are for a 96 or 97 (which is the new block) or should i be buying sensors for the car which is a 94?
Old Apr 18, 2012 | 01:59 PM
The basic engine is the same. To keep things compatible, and to avoid any chance of mis-matched wiring and plugs, I'd put it together with the same kind of sensors the engine in the car had.
yes all the sensors are the same. the opti is different like 69 is sayin but sence you are putting a 96-97 motor in a 94 then the only thing you will need is a 95-97 opti. if you are not using a newer front cover and cam then you need a spline drivin, non vented opit.
Old Apr 18, 2012 | 02:15 PM
Don't think it makes a difference which opti he uses, as long as it mates up to the engine.
Old Apr 18, 2012 | 02:16 PM
okay so how many sensor are there on the just the motor?
Old Apr 18, 2012 | 03:18 PM
i count 5 if you dont count from the intake manifold out or the opti. so not counting any sensors in the opti, tb or air intake.
